Each blank was tested with 4 different loads, which means you can generate up to 16 curves (4 blanks with 4 load patterns each).
![Image](http://www.rodhouse.fr/img/comparator/preview_uk.gif)
This tool has been validated. It is not based on simulations, but is the result of hundreds of pictures of the actual blanks, with actual weights. Each picture was treated through a precise process that guarantees that both the scale and the angle is what the blank really reacts like.
![Image](http://www.rodhouse.fr/img/comparator/photo.jpg)
Each picture was vectorized individually to ensure the accuracy of the results.
![Image](http://www.rodhouse.fr/img/comparator/vecto.jpg)
It does not get much easier than this : you select the blanks, you choose the load and you compare them. It is no rocket science to see which one is more powerful, fast or moderate, and so on.
Used to be difficult to choose a blank on the internet ? Well, now it's the easiest and most reliable way to know precisely what you're buying.
