NFC SWB 807-1 IM
MardukFIN
NFC SWB 807-1 IM
Message par MardukFIN »
Image Image
Hi again! This is 3rd time i built this awesome blank. It's absolutely best allrounder what i've ever held or fished with. Northern pike is my main target here in Finland. With lures 1-8oz.
This time i wanted to extend blank a little bit. I've got one cutted blank what was just right od to put it in. Ready rod is now 255cm long, 8'4". Original is 8'. Also wanted to try texalium handle 1st time.
So, laying epoxy inside the blank and put stump inside. Also added arbors for texalium handle.
Here's extended blank with handle tube and Fuji PLS18 reelseat:
I used to use American Tackle NIRLC full titanium guides. In this rod those are with acid wrap. 1st Stripper is 12, then 10 10 and rest 5 are 8 plus 8 top. I chose color theme to match with Daiwa Ryoga 2020. ;)
Thread i used is prowrap tiger wrap 2001 black/white. It turns very nicely after epoxy. Brilliant!
On decal i used glitter 1st time. 1st guide and decal has silver trims. Other guides doesnt have.
Here's handle again. It's 49cm from buttend to middle of the spool.
Thanks,
Pekka K, Finland
NFC: MB 705 HM, MB 806 HM, SWB 807 IM, SWB 808 IM, MB 709 SM, MB 709 IM, MB 795 Delta
Rainshadow: ETEC76M, IMMWS76ML-TC
Phenix: K2-763ML-C
St. Croix: 5C70MF-G
Re: NFC SWB 807-1 IM
Very nice build !
it's fun the carbon grip :D
Very nice rod! The butt is original, looks good! ;)
Yama
Message par Yama »
Nice rod
MardukFIN
Thanks all. I though that tube handle would be light, but it's actually 50g + all stuff inside it. So it wasnt light at all. :D
Phenix: K2-763ML-C
St. Croix: 5C70MF-G
ame666
Message par ame666 »
Well Done for your amazing rod.
Blank réalisé :
revs 54 ul 68mx immws 62l x2
HS 9000 M
mhx cb 905
Unity 6"6 ×2
REVF 9010-4 SB
Swb 809
709 im
Mhx 782
